99 es help with codes pls
Old Mar 3, 2019 | 04:55 PM
mrdpboone's Avatar
mrdpboone
Default 99 es help with codes pls
I have had my car sitting for a bit and in the past few weeks got it running again. I had to get a new alternator to start. My vsc/vsc off lights came on, Then noticed that the cylinders were missing, and check engine light started to blink.. so i went to auto zone to check for codes.
I had these codes pop up.
p1349
p0300
p0301
p0303
p0305
p1133
p1153
So i went and replaced all spark plugs, coils, 2 oxygen senors intake, and the 2 vvt solenoids.
The car was running smooth and still is, but after 30 mins of driving the check engine light and and vsc/vsc off lights came on again. Went back to check codes and came up with these today
c1241
c1251
c1223
p0441
The battery and alternator are new, which has the first code scratching my head... if anyone could be of any assistance, i would greatly appreciate it!!!
Old Mar 3, 2019 | 05:31 PM
Sounds like your alternator is bad or blown fuse(s), the battery may also be bad. The other codes may go away when you get your charging problem sorted.
Old Mar 3, 2019 | 05:38 PM
mrdpboone's Avatar
mrdpboone
Default they are new
i purchased both just 2 weeks ago. i wouldn't think they are bad. just put in new alternator in last friday. wouldn't think they were bad. also it didn't show up from original codes when cylinders were missing.
Old Mar 3, 2019 | 05:51 PM
mrdpboone's Avatar
mrdpboone
Thumbs up just fixed p0441
after some help with youtube... found that after having my oil changed, they checked air filter and disconnected the hose next to it. So checked that one off. 1 down, 3 to go.
Old Mar 5, 2019 | 03:14 PM
mrdpboone's Avatar
mrdpboone
Default that was the problem for it all
that hose was the cause of all codes... plugged in hose and reset codes. havent had check engine light on since.
gsssss
Jan 23, 2023 09:57 AM
maeveLexi
Apr 9, 2019 09:09 PM
fatcat2
Jul 17, 2018 04:08 PM
HarrierRX300
RX - 1st Gen (1999-2003)
18
Apr 10, 2016 04:16 PM
99LS400BLK
Apr 26, 2007 07:40 AM
