Adding TPMS sensors?
Old Jan 23, 2019 | 06:11 PM
ellocovg's Avatar
ellocovg
Default Adding TPMS sensors?
My wheels have the bubbling paint and I found a decent set of the nicer 2010 wheels with sensors for a decent price. Do additional sensors need to be with the tech stream or are our cars able to recognize a second set like other Toyota vehicles?
Old Jan 23, 2019 | 08:08 PM
Nad1370's Avatar
Nad1370
Each TP sensors has its own ID code.
Your current ones are registered to the TPM ECU.
Your 2010 TP sensors ID need to be registered to your TPM ECU for it to be recognize.
It usually a 6-7 digit code thats on the TP sensor itself.
It requires a techstream or some diagnostic tool to communicate with the TPS ECU for it to be registered.
Some Lexus models can take 2 sets of TP sensors.(cant remember right now)
If yours can only take one and if you choose the 2010, each sensor will need to be registered.
Old Jan 23, 2019 | 09:05 PM
Nad1370's Avatar
Nad1370
Another option is to swap your current sensors to the 2010 rims so no reg is needed.
At least you know your TP sensors are working.
i suggest to replace the seals to prevent leaks.
Some say batt life is about 10 years or so.
So.thats something to think about as well.
Old Jan 24, 2019 | 07:24 AM
jkayca's Avatar
jkayca
You can also clone the new sensors. I.e. make them appear to be the same as the old ones. There's no need to reprogram the ECU but you do need a tool to do the clone.
Old Jan 24, 2019 | 06:21 PM
ellocovg's Avatar
ellocovg
Sounds good thanks guys.
artbuc
RX - 1st Gen (1999-2003)
Jul 10, 2018 01:05 AM
britsti
IS F (2008-2014)
Mar 1, 2011 07:27 PM
tastfulmod
Jan 10, 2010 07:47 PM
moo_juice
CL of Hawaii
Jan 23, 2009 02:41 AM
ISFury
Aug 30, 2006 08:05 AM
