ClubLexus - Lexus Forum Discussion (https://www.clublexus.com/forums/)
-   ES - 1st to 6th Gen (1990-2018) (https://www.clublexus.com/forums/es-1st-to-6th-gen-1990-2018-179/)
-   -   Driver's side headlight is out (https://www.clublexus.com/forums/es-1st-to-6th-gen-1990-2018/903062-drivers-side-headlight-is-out.html)
MAJ Oct 27, 2018 08:02 AM
I have replaced the HID bulb and checked the under the hood fuse for the headlight. No joy. I even replaced the fuse just to make sure. All other lights work properly. Is there something I'm missing or need to check? I heard about a ballast but not sure of the location...
TIA,
MJ
nevernu Oct 27, 2018 09:10 AM
try the known good passenger HID in the driver slot to eliminate defective bulb socket issues
MAJ Oct 27, 2018 11:19 AM
I have tried 2 known good bulbs wit the same results.
Is there a way to test the ballast? I really dont want to slip the headlight to replace the ballast. Here's hoping its something else.
nevernu Oct 27, 2018 12:38 PM
2 Attachment(s)
https://www.clublexus.com/forums/es-...ement-diy.html
maybe something useful here
also att disassy if needed (ballast is a light control ECU )
MAJ Oct 27, 2018 01:11 PM
Thank you very much!
