Engine shuts off
97 ES 300 about once a month goes thru a cycle where when I start the car it auto shuts off I have to start in neutral so I am able to give some gas so I can then put in drive. If I am coming to a stop it will idle down then shut off. This usually last about 30 min then back to normal start and drive.
Thanks for input
Thanks for input
Sounds like you have a bad Engine Coolant Sensor ECS. They’re about $30 online and they’re usually found right where the water line from the engine exits. It’s a short metal rod that screws into the water line with a cable connector on the other end. A thermistor inside changes value as it heats up and this tells the fuel system how to run the engine at various temperatures. This happened to me with a Saturn.
qewani1
13
Oct 4, 2008 04:38 PM
