How do I remove this panel on an '01?
Old Feb 13, 2018 | 08:36 PM
GoodRevs's Avatar
GoodRevs
Default How do I remove this panel on an '01?
How do I remove the frontend, drivers side panel just in front and above the wheel? It's the panel I circled below. Thanks
Old Feb 15, 2018 | 02:51 PM
GoodRevs's Avatar
GoodRevs
Someone must know or have done this?
Old Feb 15, 2018 | 04:27 PM
It involves many steps. You'll have to remove the inner fender liner, bottom trim, front bumper, signal light etc.
Old Feb 16, 2018 | 09:12 AM
GoodRevs's Avatar
GoodRevs
So from further research it seems that I'll need to remove the side turn signal to access several bolts, then remove three bolts on top of the side fender, then two bolts on the side of the fender along the door panel, and finally remove the fender skirt to access several more bolts The side fender should then be able to be removed. Does this sound more or less correct?
Old Feb 16, 2018 | 09:44 AM
PFB's Avatar
PFB
Just curious. Why do you want to remove it?
Old Feb 16, 2018 | 10:28 AM
GoodRevs's Avatar
GoodRevs
There's some rust developing along the edges where it meets the front fender. It can't be cleaned and treated with sealant unless I remove the panel...or the surrounding panels. I want to stop it from getting worse.
Old Feb 16, 2018 | 12:46 PM
PFB's Avatar
PFB
Ok that makes sense. Smart move
Bradlar
Aug 18, 2018 06:38 PM
Adam0412
Jul 20, 2013 11:06 PM
toy4life86
Jul 26, 2010 09:02 AM
assass1n
Feb 22, 2009 06:13 PM
mongnata
Aug 2, 2003 12:41 PM
