Error Codes
Old Jan 24, 2018 | 03:59 PM
mrsjack2u's Avatar
mrsjack2u
Default Error Codes
2004 ES330 Lexus Error Codes, P0302 Misfire cylinder2 has 2 misfire, P0303, P0304
Would this be the coil pack or spark plugs or both?
Old Jan 24, 2018 | 08:24 PM
whooodat's Avatar
whooodat
It could be a number of things... here is a start (NOTE: this is from a 1998 ES300 book)
I'm thinking it could be injectors or timing. You can search threads on here for the codes, hopefully you can find more information on CL.
I came across this thread on here: https://www.clublexus.com/forums/es-...es300-ocv.html
Old Jan 25, 2018 | 03:24 PM
Oro's Avatar
Oro
Knowing mileage, condition, and service history really helps in questions like this. But, the first thing to do is to swap a coil, reset the codes and see if the error repeats or tracks with the swap. E.g.:
302 indicates front cylinder, front bank. Switch that coil with the middle one and see if you get a 302 code again, or a 304 (front bank, middle cylinder).
If it tracks with the coil, replace the coil. 303 indicates a rear bank, which is difficult to get to. if you need to swap one of them, it is worth considering replacing the plugs at the same time and possibly the valve cover gasket and plug grommets back there.
05RX330AWD
Jul 10, 2017 10:19 AM
Cleeriv777
Mar 23, 2017 05:45 PM
sktn77a
RX - 1st Gen (1999-2003)
Oct 25, 2015 12:46 PM
PDXLex
Aug 14, 2014 08:19 PM
WainiacS
Nov 28, 2011 07:04 AM
