Adjusting Window Height
Old Jun 10, 2017 | 11:34 PM
lexrod6's Avatar
lexrod6
Default Adjusting Window Height
I recently replaced the driver side window regulator, and now the window stops a bit too high when fully up. It hits the lip of the trim and the window gets stuck when trying to shut the door. After trying to adjust the 3 screws that hold the window to the regulator for 3 hours, I gave up.
My question is - are there other places to adjust max window height? Any input would be great. This is for a 1999 ES 300.
Old Jun 19, 2017 | 05:06 PM
lexrod6's Avatar
lexrod6
I just wanted to take the time and contribute back to this, and other wonderful and invaluable forums. That's right! Its time to give back.
So, if anyone else experiences the symptoms above - there are 2 bolts, which you can loosen and glide up and down, almost 3/4" of an inch max. What your moving are the actual "Stops," that the window bumpers hit. Just follow where the 2 rubber bumpers on the window go up to rest - you'll see that there are two bolts (one most likely covered in clear tape) that control this. Adjust as needed; problem solved.
I was a little discouraged when the question above was viewed over 100 times, without a single shout. All good. DYI makes the soul feel good.
Old Jun 19, 2017 | 06:54 PM
Thanks for the info. Almost all of these mechanisms have some type of stopper bolts they are especially important for doors with frameless glass.
Old Jan 9, 2021 | 10:51 AM
gwkasza's Avatar
gwkasza
Yes, there are two yellow stoppers that allow you to adjust the window height.
KevinLex11
Dec 11, 2018 07:45 AM
Ryo
15
Sep 20, 2016 08:49 AM
Eddycanuck
Feb 19, 2013 11:59 PM
jaseinatl
Apr 11, 2010 02:42 PM
wusupra
Aug 21, 2008 08:37 AM
