2003 Lexus ES300 problem
When I want to accelerate primarily from a dead stop the engine almost sticks when changing into gears and than goes (its a light jolt) almost like the gear sticks before changing. Does anyone know what this might be? Thanks.
ok. so inspect it and confirm, then replace it.
- but what you've described sounds alot more like a internal issue with the gearbox,
- a good place to start would be checking the fluid.
- perhaps pulling the drain plug, checking the magnet for metal and checking the fluid for a fine particles (silver haze in fluid)
- I've had an issue like this, and eventually the gearbox failed.
jaredmac11
Jan 28, 2017 05:29 PM
dan2563
Feb 11, 2014 02:26 PM
