Engine mis-fire?
Old May 27, 2003 | 11:32 AM
roughrider's Avatar
roughrider
Question Engine mis-fire?
I have done 110 K on 98 ES300, with routine maintenance it is still running great.....except lately while accelarating (especially between 40MPH to 60 MPH) in top gear feels like engine mis fires( or something like 'gaps' in power).
This happens expecially when you reduce the power and try to speed up again. even if I push the gas pedal softly.
Any thoughts?
RoughRider
ES300/1998/110K
Old May 27, 2003 | 12:18 PM
flipside909's Avatar
flipside909
Lexus Connoisseur
25 Year Member
Explain the situation more detailed. For the 40-60 mph surge in power that you feel, it's probably the ACIS valve that opens and closes at certain speeds and throttle.
Old May 28, 2003 | 07:42 AM
roughrider's Avatar
roughrider
OK. Here is the situation:
Initial accelaration: no problem, i.e. when I start the car and accelarate to 60 MPH, smooth.
But when I am cruising at 60, then I reduce the speed some where around 40, and accelarate again the I notice the problem. It goes away when the car accelataes back to 65 or 70.
Thanks for your help...
RoughRider
1999/ES300
Old Jun 1, 2003 | 11:15 AM
flipside909
Lexus Connoisseur
25 Year Member
RoughRider
1999/ES300
Hmm that doesn't sound normal. Have you had your valves adjusted or fuel injectors flushed out lately?
Old Jun 16, 2003 | 09:47 AM
roughrider's Avatar
roughrider
I took it to the Dealer and they adjusted the valves and flushed the injectors.
everything looks good.
Thanks every one
Old Jun 16, 2003 | 11:24 PM
flipside909
Lexus Connoisseur
25 Year Member
Great to hear. Keep us posted if any symptoms reoccur.
shortbus75
Jan 5, 2016 07:47 PM
89Rustang
28
Feb 8, 2010 01:52 AM
CrusherCur
Jan 19, 2009 05:02 PM
triplecore
Jun 21, 2006 04:47 PM
purebliss
Performance
Nov 9, 2002 08:19 PM
