Traction Control and Check Engine light on
Old Feb 15, 2017 | 09:08 AM
VES300's Avatar
VES300
Default Traction Control and Check Engine light on
I own a 2001 Lexus ES300 and my traction control and check engine lights are on. I have also had problems with my transmission if I drive on the highway for a extended period of time. Once I slow down to under 30 mph, the transmission will occasionally not shift into 4 gear (or overdrive) unless I turn off and on my car. Also there
is a slight rattling noise (similar to rocks in a can sound) in the engine area when I'm accelerating around 1500-1900 RPMs. I have tried changing to a higher grade fuel but that didn't help. I also replaced the gas cap with one from Walmart and again no solution. This car has never left me on the side of the road I just don't know how to fix her and wanted to see if anyone else was having similar problems. These are the codes that showed up.
Old Feb 15, 2017 | 11:11 PM
ES300NZ's Avatar
ES300NZ
you'll just have to replace the knock sensors, and resolve the issue with e-vapouration system
Old Feb 17, 2017 | 07:45 AM
tomf's Avatar
tomf
^ I agreee
Old Feb 22, 2017 | 01:30 PM
mpmp's Avatar
mpmp
Do not worry about the P0440 and P0442 error codes. I've been driving my little toyota with those codes for over 3 years now and still getting 45mpg in the winter (the car has over 222k miles) - the only nuisance is that the gas pump clicks every 2 seconds when filling the tank
If the charcoal canister is bad, instead of replacing it, spend the money on a ScanGage and erase the codes when they show up
Edited:
Check the easy stuff first:
Old Mar 15, 2017 | 08:37 AM
VES300's Avatar
VES300
Thanks I'm taking it to Toyota soon so i will update the situation of my car.
Old Nov 30, 2017 | 12:41 PM
flashprash's Avatar
flashprash
Did the dealer tell you what the problem was? I have the same problem
ssjkev16
May 21, 2018 12:55 PM
truffle999
Sep 20, 2016 08:28 PM
ChanIS250
Sep 23, 2013 04:13 AM
wqqclhtt
Jul 1, 2009 07:43 PM
SHY820424
RX - 1st Gen (1999-2003)
13
Jan 2, 2008 07:24 AM
