Shifting problem - P0330 code
Old May 31, 2016 | 06:46 AM
way2lo's Avatar
way2lo
Default Shifting problem - P0330 code
2001 ES300 - CEL &TRAC OFF lights are on- diag P0330-knock sensor code.
Trans. shifts into high gear one time only after driving and come to a complete stop. Turning engine off, restarting, resume driving will again shift into high gear only once, wont go further than 3rd gear. Help!
Old May 31, 2016 | 09:07 AM
crwys's Avatar
crwys
P0330 I believe points to knock sensor bank 1. It is quite a bit of work to get to your knock sensors so I would replace both and the connection wire to them.
Another possible cause is your o2 sensors are reading incorrectly. Those are much cheaper and easier to replace. If you have a obii adapter you can check your o2 sensors to see if they are working properly.
There may be a few other causes which I'm sure someone will chime in.
Also if you have any near future long road trip plans that you wish not to cancel you can check out this post.
Explains how to bypass the 3rd gear with a knock sensor code. Just remember you are taking full responsibility if anything were to happen when performing this "trick".
https://www.clublexus.com/forums/es-1st-to-4th-gen-1990-2006/806074-2000-es300-230k-no-overdrive-need-help-2.html#post9312557
Old Jun 14, 2016 | 12:15 PM
way2lo's Avatar
way2lo
Replaced knock sensor - problem resolved.
Vikingone
Oct 9, 2018 01:48 PM
shahzach
Jun 7, 2014 09:52 PM
pslack
Maintenance
Feb 1, 2013 02:42 PM
JStivers
RX - 1st Gen (1999-2003)
Jul 29, 2012 05:09 PM
TLDriver
Dec 1, 2008 12:02 PM
