Air Plenum Torque
Mar 7, 2016 | 02:06 AM
Air Plenum Torque
Will someone please confirm torque for 2003 ES300 air plenum to manifold (8mm hex fasteners). From what I read, it is around 12-15 ft-lbs. Thanks.
Mar 7, 2016 | 08:01 AM
Yes. I recall 14 ft-lbs from the reference when I recently had it off. But a tweaking each one with a wrench is not critical in this application.
You want it tight but not cranked on so hard as to deform the gasket. Same range as a spark plug roughly - snugged up and then another 1/2 turn maybe.
Mar 7, 2016 | 12:47 PM
It is aluminum so do not over torque it.
on a 96 the 8MM Hex per tech manual are 32 ft lbs ( 2 bolts and 2 nuts ) These are the set in front of the intake chamber, correct?
Mar 7, 2016 | 01:58 PM
I normally put a coat of di-electric or silicone grease on the insides of the plenum.
This is in case I need to take it off again years later so it won't be "glued" and helps to seal it from leaks.
thomasjti
Feb 12, 2015 07:51 PM
rich250x
Wheels, Tires & Brakes Forum
Apr 22, 2011 10:08 PM
donbryce
Sep 11, 2010 07:30 AM
pitmanr200
Maintenance
17
May 8, 2008 06:46 PM
hellasboy
Maintenance
Aug 11, 2003 03:44 PM
