coolant amount
Old Jan 16, 2016 | 12:32 PM
fade41's Avatar
fade41
Default coolant amount
How much coolant/water mix in gallons will I need to flush and refill 2003 es300?
Old Jan 16, 2016 | 06:42 PM
pauloil's Avatar
pauloil
if you do it with distilled H20, you can figure it out. open all the drains, fill with distilled. do this three times, then you have water in your engine and can use straight coolant to fill and get close to 50/50.
Old Jan 16, 2016 | 11:52 PM
Oro's Avatar
Oro
This depends upon whether you are just draining the radiator and refilling (less than a gallon), or trying to empty the whole system, including heater core. That's like 2.5 gallons total capacity, I think ~9.3 qts.
What are you trying to do, complete flush with block drains opened and heater core flushed out, or radiator drain/fill, or...?
zxaaron
Jun 29, 2012 09:24 PM
da7
Dec 2, 2011 01:48 AM
saelee39
Sep 13, 2010 11:17 PM
ekrebs
Nov 30, 2008 03:01 AM
poicow
Feb 6, 2008 07:24 PM
