02 lexus es300 ISSUES
Old Jul 6, 2015 | 05:34 PM
Ginolbli's Avatar
Ginolbli
Default 02 lexus es300 ISSUES
Hey guys, so today im at a stop light the light turns green i hit the gas and the car doesnt move. When my key enters the ignition a buzzing noise is now heard from the engine. I pull over etc etc get towed home. I read on the internet that with the situation im in i should clean the throttle body and or the air intake valve. I bought throttle body cleaner and used it on the butterfly throttle. The car hesitates but does end up starting after the cleaning. My check engine, vsc, and trac off lights were on so i disconnected the negative terminal on the battery and let it sit for awhile. After reconnecting, she wont start and im having electrical problems such has sunroof movement hesitation and when i use my lock button on the key a continous beeping noise occurs until i shut my doors. If you guys have ANY IDEAS OR SUGGESTIONS please feel free to give advice. Thankyou
Old Jul 6, 2015 | 06:31 PM
ES300NZ's Avatar
ES300NZ
is your battery light on ? this sounds like a failure to charge.
Old Jul 7, 2015 | 07:47 AM
Ginolbli's Avatar
Ginolbli
My battery light is not on, but weirdly enough this morning my car starts right up first try.
Old Jul 7, 2015 | 09:32 AM
Ginolbli's Avatar
Ginolbli
And now she wont start, she was towed Away
Old Jul 7, 2015 | 01:04 PM
ES300NZ's Avatar
ES300NZ
I wonder if the stater solenoid is locked on / failed. That would explain the buzzing sound, and the failure to start. It might also explain why it stalled out, if the starter was running while you were driving. just a thought.
Old Jul 7, 2015 | 02:52 PM
Megafast13's Avatar
Megafast13
Sounds like it wasn't well maintained. The issues you mentioned aren't electrical problems. When you reset the system, such as by a dead battery, the sunroof needs re calibrated. Also the alarm noise will sound if you doors are not closed when you are trying to unlock the car.
Old Jul 11, 2015 | 08:59 AM
JDMSteven's Avatar
JDMSteven
How do you go about recalibrating my sunroof, I was wondering why it wasn't working when I turn the key in the door anymore
aslowdodge
Sep 11, 2017 07:17 PM
LsG86
Feb 28, 2015 09:35 PM
andyboy
Sep 15, 2011 06:54 AM
beth
Jan 24, 2009 12:26 PM
Drewbeeee
Jul 21, 2008 09:15 PM
