Strange electrical problem
Old Apr 25, 2015 | 07:08 PM
EPayne42's Avatar
EPayne42
Default Strange electrical problem
Hello,
I own a 1999 Lexus ES300. I was screwing around with the radio trying to do an upgrade. I may have crossed some wires. I put the original radio back in the car and now my radio, turn signals, and rear tail lights aren't working. I check all of the fuses and everything seems fine.
Any idea what could be causing this?
Old Apr 25, 2015 | 07:16 PM
ES300NZ's Avatar
ES300NZ
Originally Posted by EPayne42
Hello,
I own a 1999 Lexus ES300. I was screwing around with the radio trying to do an upgrade. I may have crossed some wires. I put the original radio back in the car and now my radio, turn signals, and real tail lights aren't working. I check all of the fuses and everything seems fine.
have you checked the engine bay fuses and the ones by the drivers side ?
Old Apr 25, 2015 | 07:31 PM
EPayne42's Avatar
EPayne42
I went through them as well. All seem okay. Any chance I burned a fusible link at the + battery terminal? This is a really Odd. As a side note my cruise control didn't work prior to my messing with the radio. Also the airbag light is flashing (was doing this prior as well).
I changed my lower motor mount today. I was jacking up on the engine with a floor jack. Maybe I knocked something loose?
Old Apr 25, 2015 | 08:41 PM
EPayne42's Avatar
EPayne42
I figured out the rear tail lights and turn signals ...I had the middle air duct popped out (the one with the hazard light switch). I put it back in and the turn signals worked. The tail lights were just blown bulbs. I didn't suspect the bulbs were bad because they were working fine a couple days ago.
Soooo ...I just have a radio that won't turn on. Is there a reset process for the radio?
EPayne42
May 3, 2015 02:46 PM
yardie876
Jan 26, 2013 04:11 PM
eYezs1ck
Aug 13, 2010 06:23 AM
trhs75
RX - 1st Gen (1999-2003)
May 30, 2009 04:30 PM
tbridgers
Feb 17, 2005 05:09 PM
