Squeaky brakes while in reverse
Old Mar 18, 2015 | 02:41 PM
Wolfmom's Avatar
Wolfmom
Default Squeaky brakes while in reverse
2007 Lexus ES350 has screeching/squeaking brakes when the car is in reverse. Is this a simple fix or a costly brake repair job?
Old Mar 18, 2015 | 03:44 PM
KLF's Avatar
KLF
Probably the emergency brake. Is it only on the rear wheels? Should be a simple adjustment.
Old Mar 18, 2015 | 04:56 PM
ESh's Avatar
ESh
Are your pads worn?
Old Mar 19, 2015 | 05:44 PM
xanderES's Avatar
xanderES
^most likely this lol
Click me for answers!
The magic of the internet.
Old Mar 20, 2015 | 02:18 AM
chuyrobles's Avatar
chuyrobles
Yep, most likely worn pads. Dust can cause squeaking but you'd hear it in forward also.
Worn pads get settled in and when you back up, you go against the grain. sort of speak; there is less drag and more stutter that manifests as squeal. To minimize the noise, don't ride the brakes when in reverse. Also, pressing more firmly on the brakes should stop most squeaking.
Do check the wear level of the brakes and change them out accordingly.
Old Jun 8, 2016 | 01:18 PM
HI8R's Avatar
HI8R
Mine 2008 Lexus ES 350's 140,000 miles rear brakes sequel too when in reverse, especially if cold or after rain, for a few years now. I believe they are the original brakes.
I pulled on the the pads off and they are not worn down, but dont know enough to judge if they are glazed or damaged.
I plan on replacing them soon. Considering MaxBrakes.com slotted/drilled bake/rotor kit for only $140 front & rear!
Sexis350
Jul 2, 2017 02:02 AM
supra725
Jan 27, 2016 11:12 PM
dunnojack
May 27, 2014 02:11 PM
Eug421
Jun 24, 2007 04:10 PM
nysupraman
Jun 22, 2003 03:10 PM
