2003 es300 front passenger window does not roll down
Checked the PWR #2 fuse, it's fine.
Just to be sure, I even swapped the rear passenger window fuse with the front passenger fuse, and rear passenger window worked.
Front passenger window just makes a click when I try to open window with either front door switch.
Using keyfob, holding unlock for 3 seconds, rolls down only 3 of the windows.
I hope it's not the motor. That will probably cost 1/4 of the car's value to fix.
Sort of pissing me off because I hardly use that window. It seems that with japanese electronics, if you don't use it, you lose it.
Any other tricks? help?
Salil022
Sep 3, 2016 07:50 AM
BlackMamba
Sep 27, 2008 09:14 PM
