Passenger side power seat problems
Hi All,
I have a problem on my 2009 Lexus ES 350, this morning I found out the passenger side power seat is not moving at all in al directions (up, down, front, back etc.) However the driver's side is working. Has anyone also encountered this problem. It was working in the past, but I would not know for how long it has stopped working as I don't normally press the buttons on the passenger side except when I want to clean the car.
I tried going through the owners manual to check if it is a blown fuse, but on opening the hood the fuse referred to as Power seat fuse is big fuse that cannot be pulled, also checked the one under the steering compartment, I could not find it either as from the manual it is not a regular fuse either. On second thought I was thinking if it a blown fuse both seats should not be working except they are wired separately (I don't know, just a guess)
Please help, any step by step DIY input to troubleshoot and fix will be highly appreciated, before the dealer rips me off. if you have pictures too it will greatly help. Thanks in advance
Great Techs in the house, somebody please help. This power seat is driving me nut. I have tried checking the fuse (one under the hood) and the other under the steering wheel. The one under the hood was not removable (it is a block of fuses possibly screwed to the fuse box) but I visually looked at it and it seems ok (cant be 100% sure)
The other one under the steering wheel also seems ok. My concern is that all the motors cant go bad at the same time, please someone enlighten me on how to check if power is even supplied to the motors...........Any help at all is greatly appreciated
Kind Regards,
Tada
Kind Regards,
Tada
Acer
Aug 13, 2017 02:34 PM
ls400888
Jan 21, 2004 10:34 PM
