starting clinking noise.
Old Sep 2, 2013 | 12:44 PM
atakhan's Avatar
atakhan
Default starting clinking noise.
hi everybody, im new to this forum, cuz just boght my 2007 lexus es350, a week ago. i am having a noise kind a crrrrrrrrrrr, when i start the car. it sounds for one second only, right when it starts or as soon it starts it does go off. and then it sounds normal. it is a very loud sound that you can here together with starting sound. somebody toldmethat it is a weak battery symtom, is it true? any help please? thanks.
Old Sep 2, 2013 | 02:54 PM
Titten's Avatar
Titten
Noises you hear coming from the engine compartment/front:
Bad Bearing in Timing Belt Tensioner: woh woh woh woh
Bad Turbo: boooOOOOOOooo
Boiling Coolant: bllgh blllgggh blllllgggghh
Brake Booster Failing: hissssssssss ssss ss
Clutch Release Bearing on the Way Out: jee je je jeee
Clutch Screech: screek, screek, screek
Connecting Rod that went through the Engine Block: clicketta clicketta clicketta
Dieseling: blubBLUBblubBLUB
Engine Knock: tuckaTHUCKtuckaTHUCKtucka
Engine Reving Up and Down: vooRRRR, vooRRR, vooRRR
Fly Wheel: gurrEENK, gurrEENK, gurrENK
Loose Belt: YEEeeEEeeEEeeEEeeEEee!
Low Coolant: bwwob bwwwobbubwub
Misfire: puhVRooPuhHoo puhVROOpuhHOO
Power Steering Pump Going: nnnghuh nnnguh
Sticky Lifters: dicka, dicka, dicka, dicka
Transfer Case on the Way Out: glaghhghgghhh woongghhh
Water Pump: grrgula, grrgul,grrgula, vum wum wum wum wum
Weak Battery: wurrrrRRRRrrrrwuRRRrrr
Wiper Transmission Sound: eee eee eeee eeee
Vacuum Leak: vwishhhhhhhhhhhhhhhhhh
Which of the above more closely resembles your noise? What color is your car???
Old Sep 3, 2013 | 05:08 AM
mlacomb's Avatar
mlacomb
You forgot nagging significant other: nagnagnagnagnag
STREETGS
Jul 28, 2016 05:18 PM
AidenJ
Oct 6, 2015 01:38 PM
VSsc400
Jul 14, 2013 03:10 PM
zenn
Nov 30, 2002 08:09 AM
Intellexual
May 5, 2002 08:25 PM
