es300 engine
Old Jul 24, 2013 | 08:20 AM
SC3coupe's Avatar
SC3coupe
Default es300 engine
I am interested in 1997 ES300 150-190k miles
mmarshall warned me against the 3.0 V6 he said there is some small oil passage and causes oil to gel up and possible engine damaged ?
Can you please clarify if these years have such a problem?
Would you say this is a fairly reliable car, is it easy to work on? (Timing Belt and water pump already done around 160k)
Old Jul 24, 2013 | 11:57 AM
BDSL's Avatar
BDSL
I haven't heard such thing.
I have a 97 ES300 with more than 260k miles on the original engine.
Very reliable car. Easy to work on.
Old Jul 24, 2013 | 12:16 PM
Hayk's Avatar
Hayk
He must be referring to a news report that came out years ago. Some random mechanic in that video blamed the design of the PCV system as the culprit of the sludge issues with the 1MZFE.
The sludge issue has been discussed numerous times, but in short it's not something you should worry about as long as there is a sign of regular maintenance.
Old Jul 24, 2013 | 04:06 PM
tomf's Avatar
tomf
Yes that is true about possible sludge. The sludge usually manifests after repeated failure to change the oil or if used on very short drives where the engine doesn't reach operating temperature so that any moisture in the oil does not have a chance to evaporate. If the oil was change on time and the car driven normally sludge should not be an issue. If you are worried have someone pull the left valve cover and take a gander. 1mz-fe engines built after June of 2002 have enlarged oil passages to alleviate the potential sludge problem
These are very reliable cars. Some problems to expect would be failure of the O2 sensors and knock sensors.
The ES300's are fairly easy to work on with the exception of changing the right bank spark plugs because they are not typically accessible without removing other parts. There is lots of information on working on these because they are basically a luxury V6 Camry.
Old Jul 24, 2013 | 06:33 PM
brucelee1's Avatar
brucelee1
Buy it if it has a decent service history. My 97 was at 150K when it was totalled. Ran like a champ.
3stars1sun
Mar 13, 2017 07:17 PM
greg3852
May 4, 2015 05:12 PM
ChunkyMike
May 26, 2014 05:17 PM
imjohnphan
Oct 15, 2006 07:37 PM
tzu911
Nov 23, 2005 07:01 PM
