Please help P0125 code
Old Oct 16, 2012 | 06:19 PM
encore63's Avatar
encore63
Default Please help P0125 code
Does anybody know? I changed the thermostat and erased the code, drove for 5 minutes. The engine light is now on with the same code.
Old Oct 17, 2012 | 04:45 PM
encore63's Avatar
encore63
Default 1999 ES300 (p0125 code) please help
Does anyone know much about this code? I changed the thermostat, checked the coolant and erase the code and drove about 5 miles, the check engine light come on again with the same code.
Old Oct 17, 2012 | 05:49 PM
hzt30's Avatar
hzt30
Did you use a OEM thermostat with correct degree rating?... NEVER NEVER use lower rated T'stats
Is the engine getting up to normal operating temperature? If it is then you may have a bad coolant temperature sensor. If you have a scanner you can read the ECT that the PCM is recieving from the ECT sensor.
Another possibility could be a flakey O2 sensor. You can read the values of the O2 sensors with a scan tool.
jiggahwh0
Sep 2, 2024 02:03 AM
RayN
RX - 1st Gen (1999-2003)
13
Sep 4, 2016 07:11 AM
bkalweit
Aug 12, 2012 11:11 PM
nicos1
Oct 8, 2007 12:44 PM
squeekyM
Sep 26, 2006 07:36 AM
