Replacement key question
Old Aug 24, 2012 | 08:46 AM
Solo2's Avatar
Solo2
Default Replacement key question
I'm trying to get a repalcement key for my '02 ES cut. The ebay key that I bought is slightly longer than the original one. Is that going to be a problem?
Old Aug 24, 2012 | 04:14 PM
Timothyj's Avatar
Timothyj
I did the same thing, won't work. You are better off getting a key from The dealer. I know, you pay up the butt for it. My dealer charges $95 for a key, just the blade and case and cutting the key. They won't cut a key from e-bay any anyone else. They say it gums up there machine. I have heard of some people getting keys cut by people other then the dealer, car won't start and keys stuck in the ignition. Check your area and see if anyone will cut a key for you and the best place to buy one. I just use my key with no buttons, keep the remote one at home and take one to work. Case is all cracked up, but still works. Good luck, hope this helps.
Tim
Old Aug 27, 2012 | 07:26 AM
Solo2's Avatar
Solo2
I think I have found a solution. http://lexus.sewellparts.com/accesso...2002/4644.html
I specifically emailed them about the length of my blank. They said that a longer one will work, but a shorter than OEM one will not. So, I'm about to send mine off and I'll report back.
Old Aug 27, 2012 | 08:46 PM
Locksmithy's Avatar
Locksmithy
The length of the key must be not too short, nor too long. The ability of the vehicle to read the RFID chip in the key head is critical.
As a locksmith, I can do what most dealers can not. We carry each length of key with chip, or complete shell for those with keys that have SEPARATION ANXIETY.
One neat thing.... on MANY Lexus and Toyota, we can supply a SEPARATE remote and solid key. This eliminates the blades coming out of the shells altogether. This often costs less than the OE Key, but performs better.
Old Sep 6, 2012 | 05:47 PM
pauloil's Avatar
pauloil
Tim
my dealer took the Ebay key i got and cut it incorrectly, then made me a good one from one of their blanks, all for $35.
Old Sep 10, 2012 | 06:06 AM
Solo2's Avatar
Solo2
And Sewell has a good reputation and will gut a generic key. Two cautionary notes though: 1) I noticed that shpping is an additional charge which makes one key cut roughly around $40; if you need two, order them at one time and 2) for some bizarro reason, the club lexis price is slightly higher than the non-club price.
LexPegged
Nov 19, 2015 10:14 PM
RSpi
Oct 15, 2012 06:23 PM
ebxgsxr
Jan 5, 2012 07:24 AM
humanoid
Feb 14, 2010 08:35 AM
mrblister
Dec 27, 2008 10:25 AM
