How To: Repair your Radio Button Lights (3ES Pioneer)
Old Nov 19, 2012 | 10:01 AM
McFerran's Avatar
McFerran
[QUOTE=MrBooby;7602302]You don't want a bulb longer than 6mm, that's what I used and they were still a bit too long. The blue one that you posted is 8mm.[/QUOTE
I have come to realize that replacing the green lights is as easy as replacing the green caps on the bulbs. Do you know where I can get blue caps for the bulbs? if not maybe some kind of blue film URL's would help me tremendously. Thank you!
Old Nov 19, 2012 | 10:00 PM
Hayk's Avatar
Hayk
Sounds like a plan, let me know what you find.
Old Jan 25, 2013 | 10:43 PM
MrShim78's Avatar
MrShim78
[QUOTE=download;7220049]Great post!
I used T5 leds, cut the legs and solder 2 wires as bulb.
But the quality of leds were not so good, 1 or 2 burned out already.
HI ...what radio is that? the one you have ? its the closest to stock design i have seen and it plays mp3?
Old Jan 26, 2013 | 06:35 AM
download's Avatar
download
It is stock 98 Toyota Picnic radio with 5-disc changer, support CD mp3 only and no aux in.
Old Feb 14, 2013 | 11:13 AM
DGIKULJOT's Avatar
DGIKULJOT
Originally Posted by download
Great post!
See the reason the leds probably burned out is because you most likely didnt use a current limiting resistors. See leds need very little current compared to the original bulbs. So basically you have to put a resistor in series with the led to limit how much current will flow through those leds otherwise they will burn out alot sooner. You can google led resistor calculator but will need to know what voltage the radio supplies to those bulbs,
Old Oct 20, 2013 | 12:08 AM
jbrick's Avatar
jbrick
I really want to change all my bulbs to pink if that is a possibility someone PLEASE let me know!!
Old Feb 5, 2014 | 03:54 PM
dlamb89's Avatar
dlamb89
Does anyone know the voltage and resistance for the bulb buttons? Would really love to have those values so we can use LEDs. I've searched for a straight hour
Old Jul 31, 2014 | 06:55 PM
Tripoderik's Avatar
Tripoderik
Would love to know what size resistor to get as well, I've searched too...
Old Oct 15, 2014 | 11:21 PM
nttung1711's Avatar
nttung1711
You can use 470ohm resistor for each single led.
Old Nov 19, 2014 | 10:44 PM
funcrusher's Avatar
funcrusher
Damn dude the before and after pictures are nice lol.....I recently bought a bulb to replace the key light circle since it was out but swapped it for the glove compartment bulb which made a huge difference. I figured that's more important than the key light which is on for a second before I start the car
I need to do this for my ac controls when I put a double din in. they're very dim and its getting to me
Old Nov 20, 2014 | 10:43 AM
Hayk's Avatar
Hayk
Thank you. I'm working on a video to complement the tutorial, which should be up in the coming weeks.
Old Jan 10, 2015 | 10:51 AM
PennyLane's Avatar
PennyLane
Default 8V bulbs?
I'm installing the new bulbs now (25-995 from MCMelectronics.com and noticed on the label they are 8V. I guess they regulate the voltage down from the car's 12V or they would be burning out for people pretty quickly. I have a climate control bulb out too and will replace it with this one also. Hopefully the voltage is correct. Oh well, if it burns out early at least now I know how to do the job. By the way, there are 7 other bulbs soldered to the other side of the climate control module's board. Those would be a real pain to replace if they burn out because the display and flex cable captivate the pcb. You would have to unsolder those multi-pin connections or risk disconnecting the LED display connections to get to the bulbs.
Old Jan 10, 2015 | 07:50 PM
Hayk's Avatar
Hayk
Great question about the voltage. I personally always wondered what the voltage is for the radio. I know every electrical component in the car's 12v circuit varies. Some things are 5 volts, some things are 8, etc.
What year is your ES? The 3ES has separate lights bulbs for the HVAC.
Old Jan 10, 2015 | 08:26 PM
PennyLane's Avatar
PennyLane
Thanks for replying about the voltage, and thanks for the great instructions on replacing the bulbs. We have a '98 ES300, same color as yours (my wife's car). Penny Lane is our boat's name on facebook. She's happy with it and aiming for 300k miles or 20yrs, whichever comes last! I tested the old and new bulbs with 12V and the new ones are definitely brighter. Unfortunately the front and rear defrost buttons are not lit and I think those bulbs are the ones sandwiched within the climate control module boards. I'm game to fix those too, but I'd have to measure the voltage first to decide on replacements.
Old Jan 12, 2015 | 07:32 AM
Hayk's Avatar
Hayk
For HVAC controls on the 3ES, it is very easy to repair the backlights. Scroll through this thread to see how it works. Bulbs can be purchased through any Lexus dealer - no soldering.
https://www.clublexus.com/forums/es3...t-problem.html
