Need help with Door Part!
Trying to fix my moms 1996 es300 driver door. When I took the door panel off, I found this sitting at the bottom of the door:
Im guess it broke off at this point:
Is there anyway to fix/replace this part? Anyone know the part number or name for this item?
If you want to fix it, and assuming it's supposed to have a hole at the end, just weld a flat piece of the same thickness to the end, file/grind it down to match the broken part, and drill a hole the same size as the original. The time to drive to the junkyard and search for a match, or search for a replacement part/assembly and have it shipped to you, would, IMO, be more than the 1 1/2 hours it might take to fabricate a new end. Course, if you don't weld or have a bud who does, that might be an issue.
2horses
Apr 30, 2013 09:55 AM
nll714
Jan 19, 2010 04:38 PM
