Engine control module for 96 ES300
Old Sep 23, 2011 | 04:56 AM
pvpham's Avatar
pvpham
Default Engine control module for 96 ES300
I'm told that my 96 es300 ECM need to be replaced.
Can I use a 95 model ECM .
Thanks for your help
Old Sep 23, 2011 | 08:12 AM
Call a Lexus dealer and ask for the part number for your ECU, and to see if a number supersedes your current one. Then compare the number of your replacement ECU, it needs to either match the original exactly, or match the supersedes part.
Using a different part number can have unintended results.
Old Sep 23, 2011 | 08:53 AM
EEngineer's Avatar
EEngineer
94 95 96 are the same.
even one from a V6 camry will work. as long as the car was made in japan
Old Sep 23, 2011 | 11:53 AM
pvpham's Avatar
pvpham
Lexus2000,
Would you please clarify what you mean by " to see if a number supersedes your current one"
Thanks
Old Sep 23, 2011 | 07:50 PM
Same part number? Good to know.
Supersede means a new number (the part itself may be revised/improved) replaces an old one, and that the new part is 100% compatible with the original.
ajs1391
Mar 1, 2016 08:26 AM
Funkdoobiest
Jun 2, 2012 05:41 PM
