OEM HID low beam problem
Old Jul 23, 2011 | 02:05 AM
mgsnat75's Avatar
mgsnat75
Default OEM HID low beam problem
hi, new here to the forums and in dire need of help with this issue. i have a 2000 es300 with oem hid d2r low beams. now just recently the drivers side low beam gave out. passenger still lights. i replaced the bulb and didn't light and i also tried the supposed blown bulb on the working side and it lit up!. I've noticed that the plug doesn't spark when on unlike the other side which sparks constantly with no light in place. What could be the problem? am i experiencing electrical problems? also to note, all fuses and relays are good and not burned out. thanks.
Old Jul 23, 2011 | 11:00 AM
Megafast13's Avatar
Megafast13
It is probably your HID Ballast that had died.
Old Jul 24, 2011 | 12:09 PM
mgsnat75's Avatar
mgsnat75
where is the ballast located and how do i replace it? and where can i get another one that is not from a dealer or junk yard.
Old Oct 5, 2011 | 08:50 AM
JustDoug's Avatar
JustDoug
You can buy a ballast on ebay i just paid $130 for one, now i'm looking to see how to install it?!! Help peeps
Old Oct 5, 2011 | 09:01 AM
01LEXPL's Avatar
01LEXPL
^ take out headlamp, remove screws holding ballast. unclip the connector to the bulb.
Install new ballast, plug into bulb, reinstall headlight
80sHero
Oct 19, 2018 07:06 AM
landy
Aug 7, 2016 10:53 PM
MistyDavis
Jun 30, 2013 12:15 PM
818GS
Apr 26, 2012 09:21 AM
e11icott
Jan 17, 2012 08:36 AM
