Help!! Transmission problem
Old May 23, 2011 | 06:59 PM
Lil98civi's Avatar
Lil98civi
Default Help!! Transmission problem
Ok so I have a 1994 Lexus es300 and after letting someone drive my car the trans has stopped working and was wondering if anyone has run into a problem like this. I can put it into any gear and it will make a whirling noise and not move and witj my foot on the brake when I put it in park it will grind very loudly like it's hitting a gear or something???? Is there an adjustment or something I'm missing here?
Old May 23, 2011 | 07:15 PM
PFB's Avatar
PFB
Did you check your transmission fluid level. Too much? Too little? Color? Odor?
Make sure you check it with engine running while the car is on level ground.
Phil
Old May 23, 2011 | 07:25 PM
Lil98civi's Avatar
Lil98civi
Level is fine it's a bit dirty and smells like trans fluid. I don't think it has anything to do with the actual trans but maybe linkage of some sort maybe?? It seems to be shifting fine by the trans though?
Old May 24, 2011 | 07:48 PM
Lil98civi's Avatar
Lil98civi
Anyone had a problem like this or know what to check??
lem321
Dec 11, 2016 02:01 PM
joeccl
Jul 29, 2015 08:16 AM
bao2long
RX - 1st Gen (1999-2003)
Apr 22, 2013 11:26 AM
mohep
13
Feb 21, 2011 09:58 PM
SC4_FI
Jan 26, 2008 03:40 PM
