Won't start
Had something draining the battery when everything is off, put my dmm in series at the negative side of the battery, and started pulling relays and fuses until the draw went away. Last fuse I pulled was the dome lite, and that made the 1.8amp draw go away. Left that fuse out, hooked battery back up, instrument lites come on, but wont start. Checked start and ignition fuses, they are good. Any thoughts?
By the way, its a 1997 ES300 with 134,000. Hooked up the Actron code reader, no codes.
Steve
Lites on dash come on, no crank. Spade fuses are in and good, relays only go in one way, checked that and continuity based on schematic on side of relay, but that doesnt mean relay is functioning when power is applied. Contact could be fused together.
firelikeiy
Feb 27, 2023 11:43 AM
PMC75
Feb 8, 2013 06:30 PM
