Premium, middle grade or regular? (merged threads)
Old Aug 12, 2002 | 04:48 AM
fallabel's Avatar
fallabel
Default Premium, middle grade or regular? (merged threads)
I always put Sunoco Ultra 94 in my 1995 es 300. One of my friends who drives an alero said that he did the same, until a mechanic told him its bad for the engine. is this true? he said he get better gas mileage now that he switched to 89 octane. i really don't care what gas costs, i just do whatever's best for the lex. i know that the manual says "at least 87", but is it still ok to put 94 in?
Old Aug 12, 2002 | 06:22 AM
ShowGSLuVv's Avatar
ShowGSLuVv
Well from what I've read on here about Octane boosters and whatever, heres the deal, if ur friend is saying that he gets better gas mileage by using 87, he is more than likely just looking at how much he's spending on gas, and of course cheaper gas gonna be cheaper but to say that Higher Octane gas is bad for the car, thats pretty stupid too, I mean it'll only give u so much performance gain, if ur cars engine is only built to go up to say 91 octane, then using 94 octane won't do anything different, it wont hurt but it's not gonna give u any more power, But higher octane gas burns cleaner and more efficent and will , and dont quote me on this, but keep ur engine cleaner inside rather then using cheap gas and getting all the clogged fuel injectors or carbon deposits, if u wanna be on the safe side use some Fuel system cleaners, use the one with TECHRON and use it probably every 3-5 thousand miles, dont use it too much though cuz I read somewhere on here that it could mess up some seals in the engine, not sure which one's but any one won't be good, lol
ShOwGS
Old Aug 12, 2002 | 08:59 AM
BAWLEX94's Avatar
BAWLEX94
wait.....i thought that the ES required at least 91 Octane fuel.....someone just mentioned that you must have at least 87 octane in it.....so which is it??
Old Aug 12, 2002 | 10:45 AM
squarehat's Avatar
squarehat
The owner's manual for my '96 says to use 87 or higher. I use 89, and put some Techron in every 3000 miles, and it runs very well.
Old Aug 12, 2002 | 11:11 AM
mcelligott's Avatar
mcelligott
My 1992 ES3 manual says to use 91...
Old Aug 12, 2002 | 12:53 PM
bizarreRide's Avatar
bizarreRide
I'm pretty sure my 98 manual says 91 octane as well...
bR
Old Aug 12, 2002 | 12:56 PM
blux's Avatar
blux
I thought mine said 87..
Old Aug 12, 2002 | 04:20 PM
r4z0r3ck's Avatar
r4z0r3ck
Minimum requirement of 89 and for better performance 91. Anything above 91 is a waste of money cuz I dont think it will respond the same as the 91.
Old Aug 12, 2002 | 05:19 PM
EGainer's Avatar
EGainer
mine says use 91, but here we have 87, 89, and 93 so i use 93
Old Aug 13, 2002 | 07:13 PM
CPerez100's Avatar
CPerez100
Blux: I like your banner
COOL
Old Aug 15, 2002 | 12:00 PM
blux's Avatar
blux
haha, thanks man. just made it up the other day! =)
Old Aug 15, 2002 | 02:49 PM
SDSC300's Avatar
SDSC300
no 94 octane won't hurt your motor .. but it won't get you anymore hp either.
but you can use 87 if you want if won't hurt your motor either ... tons of people with Camry's do it and are good for 250k+ miles easy.
octane has to to do with detonation, the higher the number the more compression it can take before spontaneously igniting.
buying high octane is prob just a waist of money is this case.
does anyone think that Lexus would sell a luxury car that they say doesn't take premium .. I don't think so ... when people buy luxury they expect to buy premium fuel .. otherwise they might thing something is Wrong.
Old Aug 15, 2002 | 03:15 PM
BAWLEX94's Avatar
BAWLEX94
i saw a special on Good Morning AMerica several months ago and they basically said that buying a higher octane for any car is a complete waste of money....they had all these studies taken.....i would bet that they are right.........and to me, i would by premium gas if it really does matter....but i';d rather save a little money if im not getting anything out of it
Old Aug 15, 2002 | 04:11 PM
kreativ's Avatar
kreativ
The V6 Camry owner's manual specifies the use of regular unleaded. Value-oriented buyers don't want to have to buy premium fuel.
The V6 Camry and ES use the same engine, but the ES has VVT-i and is tuned for more power (or, you could say the Camry V6 was detuned). I'm assuming the almost 20HP more is at least partly dependant on the use of 91 octane fuel.
Good point. Although didn't previous ES owner's manual specify 87 octane?
Old Aug 15, 2002 | 04:29 PM
blux's Avatar
blux
does using a higher octane fuel really boost your power that much? I'm thinking probably not, I mean, its gas...not a turbo.. Just buy whatever you want its probably not going to hurt much unless your engine specifies that you use a higher octane, but if you have an 87 car dont even bother putting the higher stuff in UNLESS you have a performance chip, or possibly a timing advance? (well performance chip advancing the timing) am I right?
