HID Lights
Old Jul 18, 2010 | 08:48 PM
  #31
RXGS's Avatar
RXGS
Relay it is i guess
Old Jul 18, 2010 | 08:57 PM
  #32
JamesBond1's Avatar
JamesBond1
Whatever makes you sleep better. I sleep just fine without a relay.
Good luck.
Old Jul 18, 2010 | 09:01 PM
  #33
RXGS's Avatar
RXGS
Ha, you guys kill me, i know the relay is just 16 bucks, but its 16 bucks that could go to tired i need extremely badly.
Old Jul 18, 2010 | 09:10 PM
  #34
JamesBond1's Avatar
JamesBond1
If you meant to say tires...Then get those too. Keep yourself and others safe on the road.
Old Jul 18, 2010 | 09:16 PM
  #35
RXGS's Avatar
RXGS
My bad, and yep, getting them once i get back from chicago next week.
Old Jul 19, 2010 | 12:44 PM
  #36
RXGS's Avatar
RXGS
Here is what i am going to do, i am going to not buy the relay and if everything goes well i will not get one, if i sense things to go wrong i will buy it.
Old Jul 19, 2010 | 01:10 PM
  #37
JTS06Z06's Avatar
JTS06Z06
Its actually the entire wire harness that you will need which would have a relay built into it. So its not just a relay your gonna need.
I dont see how your going to be able to "sense" your wiring over heating or switches melting inside your dash but it is your call :-D Enjoy the HID's just make sure you aim them correctly!
James
Old Jul 19, 2010 | 01:14 PM
  #38
RXGS's Avatar
RXGS
O i was under the impression you just bough a relay and hook it up. Guess not.
Old Jul 19, 2010 | 03:35 PM
  #39
R1R's Avatar
R1R
The relay is attached to the harness. That is all you need.
Old Jul 19, 2010 | 05:10 PM
  #40
angmedic91's Avatar
angmedic91
Originally Posted by 01LEXPL
^^ So do others with 5 years an NO relay...
The only time and common misconception regarding relays, is those stupid 'hid headlight super bright bulbs'.
Yes, those generic 'blue' bulbs from eBay. THe only reason they are brighter is because they are overpowering your OEM wires since they are 100W, whereas OEM would be 55W.
In this instance, that's asking for trouble! Hence a relay is key with something like that, as the wiring would burn before the bulb would.
Second, the HID kit, as i mentioned already doesn't require a relay since the OEM wiring is not feeding more power thru the wires than the car can take.
It gets the same 'jolt' of power as do your OEM bulbs. With that said, do you too have a relay for your OEM bulbs? I think not.
Therefore relay harness = useless. Also, it helps that it looks like **** in the engine bay, as it clutters up the install with useless and random wires all over the place.
I have to agree with 01LEXPL. On my old car I used one of those fake HID halogen bulb that was rated for 75 watts and standard was 55 watts, anyways, I about cooked my wires trying to power a 75 watt bulb. HID kits have the ballast, and the job of the ballast is to amplify the power to the HID bulb and if you have noticed the wiring from the ballast to the bulb is a thicker gauge than then the OEM wiring that connects to the ballast.
Old Jul 19, 2010 | 05:14 PM
  #41
angmedic91's Avatar
angmedic91
Originally Posted by MoreMGD32
You have any pics of your hids? i was about to buy the DDm kits! they have a lifetime warranty too!
Sorry, I have no night pics of my HID's, but the DDM ones I have our also lifetime warranties.
Old Mar 20, 2011 | 09:55 AM
  #42
VicsIS350's Avatar
VicsIS350
Question
Originally Posted by angmedic91
I have a 98 ES300 non HID housing and I put in 8K HID's for the low beam and 6K for the fog lights. I did not use a relay, just what came with the kit, plug and play and have had no problems what so ever. I got my HID's from http://www.ddmtuning.com/products/102/
Also remember, your halogen lowbeam, high beams and fog lights are all 55 watt bulbs. The kits I installed are 35 watts, so consume less power, but the light output because they are HID's are 2-3x brighter. Because of the low wattage, there was no need to use a relay, the OEM wires are rated for a 55 watt bulbs. No chance of frying your wires. They do make 55 watt HID's, but was told they are way to bright and wash out any color, if thats what you want also. Hope this info helps out.
I have a 1996 ES300 by installing any 35w kit do you recommend I have car set to HID? Because I bought an 8k kit bi-xenon for my Benz back in 06/07 and it flickered until I had lighting set to HID instead of keeping it set to halogen.
LxsGs300
Oct 27, 2013 04:54 PM
tru_player
Jul 23, 2007 03:59 PM
cartechpr
Lighting
Dec 14, 2005 10:09 PM
dsouth
Lighting
Jun 15, 2004 12:02 PM
wutdeheck
Lighting
Oct 13, 2003 12:44 PM
