werid shaking! Need help asap!
Old Jul 13, 2010 | 08:09 AM
HYPERBOY's Avatar
HYPERBOY
Default werid shaking! Need help asap!
okk sooo I know I've beeen a ghost on the forum but heres the problem so I just changed the cv joints about 3 weeks ago and ever since then the car shakes when you go from a stop up to 2500 rpm but it also shakes when I'm on the highway and I'm in the 2000 rpm range...
soooo idk what the freak is going on, also I need a new timing belt..
ohhh and I wanna get that new pully thingy ne one have the link???
Old Jul 13, 2010 | 08:35 AM
HYPERBOY's Avatar
HYPERBOY
anybody????????????? No love.. =(
Old Jul 13, 2010 | 10:06 AM
zajac's Avatar
zajac
Is the CV seated properly in the trans? I have a similar problem but when I'm barely accelerating.
Old Jul 16, 2010 | 08:52 AM
decypher's Avatar
decypher
Lightbulb Observations
Is it shaking or a noise or a combination of both? My advice to you is start taking notes and keep a "blocked out" driver time log of your observations (Ie: 8am-8:30am = Drive to work, 12pm-1pm = drive on lunch break, 5pm-5:30pm = drive home from work, 7:30pm-9pm = drive to the beach club), these just some examples...
First thing in the morning when the engine compartment is cooler-- is it better? worse? the same? How about in the afternoon? Night? Maybe even consider the weather; Hot/Humid? Hot/Dry? Cool/Dry? Raining/Flooding? Below freezing? etc.
Notice what happens when driving on washboard surfaces? Dips? Bumps? Smooth asphalt? Notice the speed you are traveling when it occurs, the RPMs, turning left, turning right, in reverse-- if there are any sounds do they carry on for a few seconds or are they quick/abrupt? Etc. Etc.
Completely turn off the head unit and remove anything in your car that could be making noise (Ie: stuff rolling around, cd cases, things in the door compartments, center console, glove box, trunk, secure any tools/jack in the trunk, back seat, rear floor, in the door handles etc.) Try listening with the windows up, windows down-- drive parallel to a large long solid brick/block wall with the windows down--do you notice any sounds bounce off the surface back to your ears?
Make a detailed log and then share your perceptions with a mechanic and even the forums. Good luck mang...
Regards,
Ryan
Old Aug 15, 2010 | 07:28 AM
Tecknician's Avatar
Tecknician
If a symptom occurred AFTER you worked on a particular part, then I would suggest you re-visit that area of your vehicle and ensure that you re-assembled everything correctly.
Another thing to check for is poor quality/defective replacement parts.
Good luck
Norman9208
Jul 4, 2015 10:24 AM
JSM
13
Nov 14, 2012 03:03 PM
Och
16
Apr 15, 2010 05:28 PM
LexTom
Feb 28, 2007 06:16 AM
EvoTuned
Apr 11, 2002 03:41 PM
