New TO CL
Damm i really want that lip well how much will a full suspension cost me i want it to be lowered without sacrificing the ride quality or if there is another way thats cheaper let me know it will be appreciated
Couple ways to lower it, lowered springs and KYB struts, will lower you 1-2.5 inches depending on brand of spring, will cost you around $600-$700, depending where you get them from. Ride is close to stock I'm told or you can go with coilovers. I have seen some coilovers on ebay as low as $800, also depends on brand, ride quality is a lot stiffer than stock, but will allow you to adjust the height whenever you want and your able to adjust the stiffness too. Going with the first option, your stuck with one height and no quality of ride adjustment. Hope this helps you out. I personally just bought K-Sport coilovers, due to cost and the ablilty to make adjustments. I wanted JIC's, but been told on back order from Japan and one vendor told me they have been discontinued for the 3rd gen ES, plus they cost several hundred more. Good luck bro.
