99 Es300 engine help needed.
Old Jul 9, 2009 | 12:22 AM
GS300916's Avatar
GS300916
Default 99 Es300 engine help needed.
I picked up a 99 es300 today with a blown motor and i been calling around to find a replacement.
Most engines are usually interchangable but it seems the 99 es300 is eclusive to only the 99.
Anyone know which will fit in the 99? its a high likelyhood the head and block are the same and only the bolt on stuff are different.
Any help appreciated.
Old Jul 9, 2009 | 12:41 AM
ASG14's Avatar
ASG14
This is from the Toyota parts catalog:
Short block, es300 - 3.0l - 3.0L 99-03 $3,353.19 $2,850.21
Includes: Block, Pistons & Rings, Connecting Rod & Connecting Rod Bearings, Crankshaft & Main Bearings.
Cylinder head, es300, right - 3.0l - 3.0L 99-03 $928.46 $789.19
Cylinder head, es300, left - 3.0l - 3.0L 99-03 $928.46 $789.19
Looks like the 99-03 main block and heads are the same. But I'll guess most of the acessories and electronics are different. Hope this helps out.
Someone please correct me if I'm wrong!
Old Jul 9, 2009 | 06:25 AM
GS300916's Avatar
GS300916
I got the same info using one of the junk yard databases im just more worried why the 99 would only be interchangable for one year. I checked exhaust manifold and intake manifolds and they seem to be the same.
Old Jul 9, 2009 | 07:09 AM
01LEXPL's Avatar
01LEXPL
Were the motors from 99-03 the same? [as per above?]
Unless I'm thinking that the '99 had something 'different' about it being the first production year of the VVTI version in the ES300...
Old Jul 9, 2009 | 08:49 AM
ASG14's Avatar
ASG14
^ I'm going to guess it;s something like the '94 1MZ vs the 95-98 ones. The '94 was a 1 year engine, and even the block was SLIGHTLY different. But you can still swap it with a 95-98. But the '99 actually lists at the same shortblock and heads from 99-03.
Actually, the '94, '95, '96, and '97 1MZ engine's are ALL different, as crazy as that sounds. But all the base shortblocks and heads are the same.
I'm sure a lot of the sensors and accessories are different.
Old Jul 10, 2009 | 08:06 AM
GS300916's Avatar
GS300916
The only thing im seeing different or non interchangable is the exhaust manifold they seem to be different.
I will try to get the 03 motor since i believe its when toyota fix the engine sludge issue?
Also not to mention the lower miles.
whiskywine
Apr 19, 2019 08:27 AM
McMuffin
Sep 26, 2015 07:36 PM
lumpy85
Aug 6, 2010 04:36 PM
one30boy
Lexus Vehicles Classifieds
Dec 10, 2004 06:08 AM
