Headlight Plug ...Help!!!
2000 es300
I think I burned up the plug that plugs into the back of my left front headlight. It is on the end of the wire harness. What is this plug called? Any info on replacing it would also help ...lol
Thanks
Cujo
Thanks
Cujo
I had a similar issue with an Infiniti that I had. I went to an auto parts store and told them which bulb it was for and they had one for about $10. It took me about 15 minutes to cut and splice the new wires and then it was as good as new. I think the bulb for the low beams (outside) is H7 and 9005 for the high beams (inside) on your year ES with halogens. Hope this helps!
