Still need help with trunk leak
Here is a picture where I am getting water. It leaks from around the bolt in the left of the picture that holds the bumper cover on and from the seam that is below the bolt and extends to the right.Is there anyone out there that has repaired this problem or removed the bumper cover and can tell me what I may be getting into. Thanks for your help.
Thanks IIcoolpass, I did that around the bolt and that partially solved the problem. If I seal it from the inside water is going to be trapped between the metal surfaces and will likely cause rust.
Nyaa
Oct 22, 2020 10:55 AM
ET94
Jun 10, 2019 11:50 AM
