dash lights
Old Mar 31, 2009 | 09:36 PM
acc's Avatar
acc
Question dash lights
hi i am having a problem with my dash lights that i just replaced with leds from v-leds.com my speedometer lights up but my rpm gauge does not and switched the leds from the rpm side to the speedometer side and they work. My prblem is could it be a bad connector or the whole circuit board is fried so give some sugestion what the problem could be or should i get a cluster from the junkyard.
Old Mar 31, 2009 | 10:02 PM
Lazy's Avatar
Lazy
I would say bad connection on it but would have to see it in person. You can always run wires from the speedo side and make it work.
Old Apr 1, 2009 | 05:41 AM
mmatheny's Avatar
mmatheny
And check the voltage at the LED.
Old Apr 1, 2009 | 12:48 PM
Lexucan's Avatar
Lexucan
Lexucanafer
There is a good chance you might have the LED polarity backwards in some of the sockets. If the polarity is off, the LED won't light up.
Old Apr 1, 2009 | 05:48 PM
tomstep2's Avatar
tomstep2
If you are having problems with your dash lights, check with a member named O.L.T., he does dash lights on 92 - 96 ES. He did mine when my needles went out. Couldn't be happier and he does offer a lifetime warranty. You can look under the vendor marketplace here on CL, or check out his website at: www.lextech.org
petendeb
Sep 19, 2021 10:23 AM
airahcaz
Nov 13, 2015 06:18 PM
TruongJL
Lighting
Jul 13, 2014 10:57 AM
puff
Jan 29, 2010 11:48 AM
LAMF
Oct 22, 2006 12:08 AM
