Thinking about buying a 01
Old Dec 12, 2008 | 08:58 PM
BMWZ3's Avatar
BMWZ3
Default Thinking about buying a 01
How do you keep the engine from "Gelling" up? Is their some way to clean it or prevent it besides 3k interval oil changes?
Old Dec 13, 2008 | 10:54 AM
MJHSC400's Avatar
MJHSC400
That's the reason they were building up sludge is neglegent owners not changing the oil often enough.
Check under the oil cap on top of the motor for sludge buildup and on the bottom of the cap, youll see it on there.. Ours has a little but were keeping track of the oil changes and it's doing good so far.
Also pull the dipstick to check the color of the oil, if it's black dont touch it, browns ok but black oil with no oil change sticker on the window is a good sign it hasnt been taken good care of.
That doesnt mean it will be a bad car and if its not a car with all maintenance records from someone you trust just get it checked out, have the compression tested on all cylinders and pull codes if the check engine light is on to be sure its not something costly.....
If you get the car cheap enough and its nice enough its worth buying even if it has a sludge motor. Just take care of it and change the oil often and replace the motor if it ever pops, and if it doesnt congratulations.
Old Dec 13, 2008 | 02:22 PM
BMWZ3's Avatar
BMWZ3
I finally worked up the courage to call the guy (1.5hours away), and it's sold. UGHHHHHHHH. My luck.
hsmac
RX - 1st Gen (1999-2003)
59
May 23, 2016 12:59 AM
sagarx
Nov 3, 2009 10:23 AM
Ac93sc
Aug 5, 2007 06:03 PM
HarrierRX300
Mar 10, 2007 04:50 AM
nkt001
Aug 23, 2006 09:56 AM
