99 es300 p0340 code
Replaced the bank 1 OS/AF sensor with an EOm from Lexus to fix code p1135 code. Cleared the codes. Now I get a p0340 - Camshaft sensor code. Any advice on how to check to see if this is bad and where is this thing located?
There are two camshaft position sensors, one is located near the O2 sensor. Chances are you may have bumped the connector while you were replacing the O2 sensor. I tried uploading a picture, but I haven't fiqured that one out yet. If you like, I could email you the diagram it you are having problems finding it.
I determined after further review that the two wires came out of the camshaft sensor connector, now I need to determine which one goes back where. There is a white wire and a red wire. Any ideas?
grillzrho
Apr 24, 2013 09:16 PM
