Headlight Fix Pleasee!!!
Old Sep 29, 2008 | 06:13 PM
johnyboiiy's Avatar
johnyboiiy
Cool Headlight Fix Pleasee!!!
i recently took my car to the car wash and chose the power wash from underneath the car option and now my right headlight has water and fog in it! btw it never had a problem when it rains so i wanna get some tips on how i can fix the problem so this doesnt happen again.
2005 es 330
Old Sep 30, 2008 | 12:03 AM
wooker_nok's Avatar
wooker_nok
Yes It Happens Alot ,It happen to my sc400 but since i have the right tools i fixed with no problem the only tool ull need is a heat gun and time,remove the headlight from ur ride and heat up the end of the clear plastic carefully to melt the sealant and apply presure to it while it cools up use a wood clamp...
hit me up if you eneed more info....i think ive got sum pictures
Old Sep 30, 2008 | 06:49 AM
BadViper22's Avatar
BadViper22
Um.. don't do that again?
There's air vents in the back of your headlight to release moisture and im pretty sure some water was squirted in there. You could try resealing the silicone.. but seeing as yours is a 2005 and only 3 yrs old the silicone couldn't be that bad.
Old Sep 30, 2008 | 08:37 AM
paintrain's Avatar
paintrain
yea just go easy on the power washer near the headlights. the heat from the bulb should evaporate the water and it should escape out the air vents. if not then the seal is broken, but i doubt it
100bajan
Apr 18, 2016 08:48 PM
MDHLexus
Mar 8, 2015 09:52 PM
winwin4all
Oct 31, 2012 07:34 AM
cali808
23
Jan 11, 2009 12:52 AM
mr_dpark
Jan 6, 2007 11:32 AM
