Sloppy Shifter
Old Jun 21, 2008 | 12:17 PM
big basset's Avatar
big basset
Default Sloppy Shifter
To people with the manual es300...if you hade a loose/sloppy shifter how did you go about fixing it? did you buy new bushings?
Old Jun 21, 2008 | 03:29 PM
llcoolpass's Avatar
llcoolpass
dude i have same, and i think it will just replace the cables and bushings since that's the main thing
Old Jun 21, 2008 | 04:09 PM
big basset's Avatar
big basset
I didn't know it uses cables..always thought it uses rods. I think the plastic bushings at the shift lever are worn out or cracked. I replaced these bushings on my 1986 corolla and the ****er is tight again..feels much better
Old Jun 21, 2008 | 09:43 PM
llcoolpass's Avatar
llcoolpass
AHH I see all your confusion. yes this car is not set up like that. my mazda 626 v6/5spd was. there was a couple of bushings that would rot away and you replace and you have no more problem.
this car is unfortunately not that way. it has cable linkage, not solid. sorry to inform you. but i believe any slop is from the cable wearing out and perhaps the little bit of a bushing where the cable ends. I do not know if that is all that needs to be replaced, but that is what i plan on doing, when the slop becomes bad. right now it's not a big deal.
Old Jun 21, 2008 | 11:26 PM
tuan92129's Avatar
tuan92129
Welcome to CL!
BTW, Awesome sn,
I'm surprised no one took that one yet.
Old Jun 22, 2008 | 10:25 AM
MCG33's Avatar
MCG33
Replace your bushings. Mine is really sloppy as well, and my parts guy at the dealership told me there are 11 of them total. 4 of them hold the base of the shifter, another 5 within the base of the shifter and 2 under the hood connected to the linkages (pictured below). I imagine changing the linkages might help too, but you should notice a big improvement with just the bushings. You can find OEM replacements through the dealer, or there are aluminum ones available on ebay for much cheaper.
Old Jun 24, 2008 | 12:52 AM
big basset's Avatar
big basset
Originally Posted by tuan92129
Welcome to CL!
BTW, Awesome sn,
thanks. This is a great site.
The white plastic thing that the shifter sits in might be worn out on mine. I will have to get ahold of the part number or name. It has four slits on it and i dont know if its craked or came that way
m2bad4ya
May 21, 2021 12:12 AM
Nomis
Jan 25, 2013 06:37 AM
emoFTW
Dec 3, 2012 11:10 PM
1siksc
SC400 / 300 Classifieds
Apr 28, 2010 07:29 PM
mrshabo
Aug 25, 2003 11:06 AM
