95 es300, My interior door lights do not come on when the door is opened. I physically inspected one of the bulbs and it appears to be good. Is there a fuse or faulty wiring that I can check?
Does your interior dome light come on when you open the door? If not, maybe the problem is your door switch/sensor. And sometimes the bulb can look okay upon inspection but still be dead. I'd try a new bulb first and see what happens. It should be a #194.
The dome light comes on. Upon inspection of the door light, it appears to be ok. I should try a replacement. Are they usually available at an AutoZone or Pep Boys?
Is that little nub that senses the door stuck? I had that problem with my back passenger doors and all I have to do is tap the button and then everything works O.o
check the fuses. i could tell you which one it is but its late and i dont feel like walkin downstairs to check. jus check the label/guide on the fuse box lid. ull figure it out
jsm1284 is his name. i hate to pawn him off on someone else since its against my better judgement but im sloppy messed up right now so im sure he'll forgive me. he does nkiow hiw stuff
