ES300: Replacing Cluster Backlighting Bulbs
http://cgi.ebay.com/10pcs-286-Wide-A...item3358e0dc43
IM TRYING TO ORDER NOW BUT I COULDN'T FIND THE T1.5, I FOUND THIS 286 WIDE ANGLE LED FROM JP_2002 SO WILL THAT FIT ???
http://cgi.ebay.com/20-x-White-LED-D...item3efb708d5c
Anyone know how wide the light distribution is for the smds?
i have went to the auto part stores and tried bulb # 24 74 194 and toyota part no 90069-98004 not one would work #194 was to big #24 #74 and toyots part no. 90069-98004 bulb no 203 were all to small they wiggled a lot and now wouldnt stay in now toyota order part no 83119-24570 from lexus and i dont know what i am going to do if it dosnt work i have taken apart the instrument cluster 4 times
i dont need any instruction on how to do it any more but i am wonder why the bulb work for others but not me what gives
i have a 95 es300
i have a 95 es300
If the bulbs are fitting loosely, you should be able to adjust the two wire contacts at the base of the bulbs (making them into a "V" shape) so that they fit more snugly into the socket bases.
These bulbs are narrower in width than the original, and have a long, narrow neck. That what keeps them from nestling down into the receptacle like the originals.
ive done this several times with no problems.
pull the ecu fuse for 5 min
or
remove the negative terminal off the battery for 15 min.
plus you get the chance to drive like a bat outta hell(yes they drive lex) and the car tunes accordingly.
great writup, im enjoying my lextech cluster.
people pace me on the hwy to check it out. its funny.
or
hey lexucan, do u think can i buy a new sockets for those bulbs can u help me please cause i just done it and only half of the cluster working, if i have any chance ill post the picture later on, thanks.
Check the write-up on the first page and you'll see a photo with the proper polarity (+/-) marked for each socket. Another possibility is that you received some bad LEDs. Do you have any spares that you could use if some of the ones you installed are not working? The third possibility is the sockets, but this is not very likely.
wat do you mean spares,you mean like a tester or something,if right can u tell me where i can buy those pleasesss,many thankd
By "spares" I meant extra LED bulbs, or in other words, more LEDS than the 8 you need for your cluster backlighting. If you have extra LEDs, remove the one/s that aren't lighting up and try another.
how can i know if i plugged the LED bulbs into the sockets correctly, because i couldn't see any proper polarity mark on the LED so how can i find out which is (-) and (+) on the LED bulbs? or the socket? do you have any pics to explain that will help alot many thanks......
1.Bent the wires of the bulb outward to form a V.
2.Bent the contacts in the bulb holder inward to apply pressure on the bulbs
3.Placed a dab of Blue Silicone RTV Gasket Maker on the lower curved portion of the bulb before inserting the bulbs into the holder. I wanted to remove any potential jiggling of the bulbs in the holders when on the road. I wanted to use silicone so that if in the future I needed to replace a bulb I could remove the material without damaging the holder. I went for the Permatex 6B because it can withstand high heat (on the bulb), good to 500 degrees F, and because I had an unopened tube on the shelf ;-).
Everything is working now, and I am most thankful to those who have gone before. A very special thanks to Lexucan for the great instructions.
Like others, the most difficult task was getting the 3 wiring harnesses detached. They had been coupled for 15 years and didn't want to break up. I had reasonable success using needle nosed pliers to hold the release detent in while using a flat knife blade to separate the connectors. I did have to take a couple attitude adjustment breaks along the way.
'96 ES300
