Tail lights out
Old Dec 21, 2006 | 01:43 PM
bublik's Avatar
bublik
Exclamation Tail lights out
This isnt as simple as it seems. ive searched etc.
The inner right tail light, Blinker rear, blinker front, and right license plate light are out.
Fuses = check and fine
Bulbs = checked and fine
Anyone?
Old Dec 21, 2006 | 07:36 PM
lexusk8's Avatar
lexusk8
It would help out a LOT if you tell us the model year of your ES..
Old Dec 22, 2006 | 08:20 AM
bublik's Avatar
bublik
Im sorry 98, any suggestions?
Old Dec 23, 2006 | 01:11 AM
sur4dude's Avatar
sur4dude
Registered User
Similar situation for me when my back up lights didn't work when car was placed in reverse. Mine's a 99 though, might be similar. Turns out it wasn't trans related, fuse, or bulbs. It was the wiring!
Check the bundle of wire that run down from the trunk lid, to hinge, and into the trunk. The wires connect to the reverse light, trunk light, and probably inner tail lights too. I didn't confirm this. I just cut and re-crimped every wire in the bundle.
Follow it into the trunk. There is a plastic housing that neatly hides the wires that is attached to the trunk lid hinge. Check for kinked wire(s) at the end of that plastic housing. That's where my wires were kinked. The wire tubing was still intact, but the wire inside was not making solid connection. It's like bending the paperclip back/forth until it breaks. Well my wires broke inside the wire tubing. I had to cut the kinked section and re-crimped the wires. I just bought wire looms and zipped tied it to the hinge. I didn't want to use that plastic housing again.
nallenium
Apr 9, 2023 06:26 PM
Barnabas
May 1, 2017 07:45 PM
tbpup
12
Oct 11, 2016 02:11 PM
Alexbenz
Jun 17, 2015 07:53 PM
Lexus99es
Sep 9, 2014 06:12 AM
