Funny wind noise comment.
Old Dec 11, 2006 | 02:32 PM
ES350Bob's Avatar
ES350Bob
Originally Posted by terryes
Don't believe I said michelin's were associated with "wind noise".
As you said in your post, the Michelin's were noisy over concrete surfaces and expansion joints, and that was one of the main reasons you changed tires. I am experiencing just such noise, and imho, it may be interpreted as wind noise to some. sorry for the confusion.....
I doubt very seriously anyone would confuse wind noise with tire noise, unless they are the type of person who would take the cat to the Vet when it is the dog that is sick.
Old Dec 11, 2006 | 05:22 PM
Citylights's Avatar
Citylights
That is really funny!
Old Dec 12, 2006 | 09:04 AM
ES350Bob's Avatar
ES350Bob
Thanks City, on short notice I came up with the best analogy I could.
Old Dec 12, 2006 | 04:59 PM
toneman's Avatar
toneman
I would like to offer something regarding the whole wind noise issue...mind you, I'm speaking based on what I've experienced w/ my ES 350. Anyways, I hear a wee bit of wind noise once I go past around 45 mph or so...and definitely hear it once I go past 55. The thing I wanted to offer is that, when I put my hand near the very top of the window frame (inside the vehicle) while my vehicle is moving at a decent clip, I can feel a faint but definitely perceptible draft coming in around that area. I even opened and closed the window just to see if perhaps the window did not close/seal tightly--the faint draft was still there. Mind you, the draft wasn't anywhere near strong enough to blow my hair or anything like that, but I could definitely feel a cool/cold draft.
I guess the question I would like to ask of fellow ES 350 owners--drive your car up to speed (e.g., around 55 mph or so), then place your bare hand next to the top of the window frame and tell me if you can feel a very faint but noticeable draft. Either that, or just tell me that this is normal for vehicles of all makes and models...
Old Dec 13, 2006 | 09:48 AM
dreyfus's Avatar
dreyfus
Tried it. No draft.
I do have some dissatisfaction with the quietness of my car (I think it should be quieter for the money), but I don't have the infamous wind issue that so many others here describe.
Old Dec 14, 2006 | 02:37 PM
toneman's Avatar
toneman
Anyone else besides dreyfus willing to see if they're getting a draft similar to what I described? I guess since dreyfus says he's not getting any wind noise, it would seem to make sense that he wasn't able to detect any sort of draft either...
Old Dec 14, 2006 | 07:00 PM
wanderer99's Avatar
wanderer99
Originally Posted by 2thfixr
Agreed, the noise is from the A-pillar area and not anywhere near the B-pillars. FWIW, the car did not have the noise @ purchase. Regardless, it's enough to drive my mother in law crazy. I will be making 2 appointments tomorrow.
1. ES wind noise
2. GS dash rattle
If it sounds like it is coming from within the A-pillar itself (or close to it) and this wasn't there when you purchased your car, my bet is one of the plugs fell out under the car.
Old Dec 14, 2006 | 07:02 PM
wanderer99's Avatar
wanderer99
I have felt this 'draft' or cold air at the top rear of my front drivers window. Its hard to know where its coming from though, as it could be just air bounced up off the window from the Air system in the car. It sure feels like it is coming from the outside, but its also only a very small airflow as you mentioned.
Old Dec 15, 2006 | 06:14 AM
static's Avatar
static
I just noticed this on my ES this morning, when you open the driver or passenger front door, look at the seal that is attached to the rear door that is between the doors when they are closed. The top 2 inches or so, the seal is folded inward and it's not made of soft material. When both doors are closed, that leaves a cavity, but only at the top. That cavity is right where I hear the noise. Could it be that they just need to redesign that seal so there is no cavity?
Old Dec 15, 2006 | 06:18 AM
ES350Bob's Avatar
ES350Bob
that is the same area my father said was part of the problem...he pulled it to left standing outside doors and folded it outward and then let it go, in hopes it then had enough resistance to closing-back edge of driver door.
Quite frankly the flimsy gasket at that area looks cheap.
Old Dec 15, 2006 | 06:59 AM
LexBob2's Avatar
LexBob2
I was out yesterday and felt around that area of the window and didn't detect any leakage or wind noise. It was windy around here too.
Old Dec 15, 2006 | 08:28 PM
psp's Avatar
psp
No draft and no wind noise. The tires are kind of noisy on some roads. There is a nice stretch of fairly new tarmac on the 101 northbound by the SFO airport. The car is particularly quiet there. I have the Michelin all season tires which are kind of noisy on concrete. My next set will be summer tires. I would like to find the right size Yokohama, Nitto, or Conti.
USCRugby
Mar 10, 2024 04:59 PM
pinoiryder
Feb 7, 2011 09:50 AM
ChrisM910
Apr 25, 2006 01:41 PM
YoungP08
Mar 17, 2006 10:26 AM
49GS400
Aug 4, 2005 09:25 PM
