question about changing front engine mount
Old Dec 6, 2006 | 04:58 PM
vinny186's Avatar
vinny186
Default question about changing front engine mount
Is it easier to change the mount from above or do i need to get under the car?
Any other tips I should know that will make the job easier? I already know to support the oil pan with a broad board and a lift.
Thanks
Old Dec 7, 2006 | 01:19 AM
FwC's Avatar
FwC
You have to take off the screws from the bottom and the top. I took mine off from the top, just took off all bolts after taking off from the engine and slid it forward. From there I just kinda swiveled it around the oil filter and between the exhaust and radiator/cooling fan. Oh yea, I also discovered that it was easier to install the new mount after you take off the bracket that attaches it to the block. Make sure you put that rubber protector on your new mount too, it protects it from the oil and other crap. You need to line up the holes though.
Old Dec 7, 2006 | 08:53 AM
vinny186's Avatar
vinny186
Good explanation, thanks.
lexina
RX - 1st Gen (1999-2003)
Jun 28, 2016 11:32 AM
worldforgo
Oct 31, 2011 01:31 AM
maxbreaker
18
May 14, 2008 01:55 PM
97-SC300
Oct 23, 2006 07:55 AM
PES300
Aug 23, 2005 08:22 AM
