Power steering problem
Old Sep 28, 2006 | 02:04 PM
Brando's Avatar
Brando
Question Power steering problem
Anyone ever changed the power steering pump on our cars? Is it very hard, anything in particular to look out for? I am getting one as mine is failing and would like to put a new one on my 93 ES300. Any how-to's anywhere? Thanks.
Old Sep 28, 2006 | 07:47 PM
FwC's Avatar
FwC
How do you know it's failing?
Old Sep 29, 2006 | 06:08 AM
Brando's Avatar
Brando
I know it is failing because it is making alot of noise and the bearing is so bad you can pull on the pulley and it just wobbles all over the place. It is also leaking quite badly.
Old Sep 29, 2006 | 07:58 AM
Tammy's Avatar
Tammy
Jack stand and remove the right front wheel. Safety first; as you'll be loosening bolts, a jack alone may slip or fail.
The pump is right in front of you in the wheel well.
Replacement seems pretty straight forward.
I have used the Goodyear Poly-V flat belts with great results. A new pump deserves a new belt ...
tooldforth
May 20, 2018 03:04 PM
Gustufsun
Oct 3, 2014 11:14 PM
Brando
Aug 18, 2006 06:19 PM
92es300v6
Aug 10, 2005 06:03 PM
kmn5
Maintenance
Jan 16, 2004 05:24 AM
