I need help asap
Old Mar 21, 2006 | 03:43 PM
papachino's Avatar
papachino
Default I need help asap
I was having transmisson problems on a trop before so I decided to change the fluid. It seemed to improve so I got a tranny flush. It worked fine on the way back home yesterday (45 mile trip) but on the way to Walmart it started slipping again. I took 6,000 rpms to get it to change gears. Please tell me it isn't the torque converter or I need a tranny rebuil, those two things are way out of my funds.
Here is more info on a previous thread
Thanks!
Old Mar 21, 2006 | 07:09 PM
Pheonix's Avatar
Pheonix
Cool
I would think rebuild the transmission / low line pressure. Could be a wheel speed sensor, or a shift solenoid going crazy. Tho that type of problem will throw a flashing O/D light (stored code).
Check the line pressure & make sure it's high enough. Tighten the kick-down cable a bit more to try and get more pressure.
Old Mar 22, 2006 | 03:15 PM
papachino's Avatar
papachino
k thanks, do you mind giving all that you know on doing a manual tranny swap; i.e. the type of transmissions compatible including all wheel drive platforms. things needed to convert, things needed to toss. thanks
Old Mar 22, 2006 | 04:50 PM
swfla's Avatar
swfla
Sorry to hear the flush didn't do the trick
IMHO, when having a costly and complicated job done, it is worth considering which shop will ABSOLUTELY , POSITIVELY stand behind it's work. Talk to your dealership service dept. They may be able to recommend some creative solutions. I remember you saying that you found finger tight bolts from the last service you had on your tranny. Definitely stay away from those guys. Good luck and keep us posted...
shenry500
GS F (2016-present)
23
Dec 29, 2018 05:58 PM
Diemellz
GS - 1st Gen (1993-1997)
Nov 15, 2008 10:25 AM
papachino
Maintenance
Mar 23, 2006 02:33 PM
Jonathan o
May 19, 2005 08:54 AM
DaveGS4
Maintenance
Jul 27, 2004 03:25 PM
