Will These Rub??
Old Jul 19, 2001 | 06:44 PM
cialz's Avatar
cialz
hey guys
will these rub on my car?
18" x 8.5"
5 lug pattern for 5x114.3 (5x4.5") LUG PATTERNS
Offset is 40mm ..
FALKEN 235/40 series tires
they fit right??
anyone know anything bout these tires??
thanks
also how bad will it rub and is it fixable
im thinking bout dropping the car one inch
and now can i fix it so i wont rub??
thanks again
Old Jul 19, 2001 | 06:47 PM
cialz's Avatar
cialz
95 es300 by the way
also can i get 225 to fit on this rim size?
Old Jul 19, 2001 | 11:35 PM
lobo's Avatar
lobo
Default Will these rub
Whats up cialz That would be pushing it I mean I used to have 18x8.5 with 235/40/18 and it rubbed alot even with the fender lips shaved I now have 18x8 with a 40 offset and and 225/40/18 tire and a 1.6 inch drop, it is perfect, my cousin has the same size rim and tire his fender lips aren't shaved and his car is dropped 1.6 also and his car only rubs in the back when he has his car loaded down in the back while making a fast turn which you shouldn't do anyways so if you want to be safe go with the same set up any other questions let me know,
-lobo-
Old Jul 19, 2001 | 11:57 PM
cialz's Avatar
cialz
cuz im gettin these rims of someone so ill have to stick with these sizes
do u know if i can get 225 on these rims?
so they will rub even with a one inch drop?
Old Jul 20, 2001 | 11:31 PM
lobo's Avatar
lobo
Default will these rub
Whats crackin cialz yes you can put a 225 width tire on an 8.5" width rim, I used toi have 225 on a 8.5" rim and was very unhappy I was so because the tire will not fill out the whole width of the rim , my rim stuck out past the tire on each side exposing the the rim which led to me getting scratches on my rim so it is up to you you can do it I did but I ended up selling my tires after like two months I mean it looks like the tire was streching to tire to fill out the width of the rim I didn't feel comfortable knowing that my rim was exposed on the sides like that making it more vulnerable to potholes etc. so yes you can do it and you would probably be okay if you only drop it one inch, if you get the fender lips shaved then you would be alright for sure so it is up to you just sharing my experience I have made a lot of mistakes while trying to make my car better and I have learned from them and now I have the perfect wheel/tire, lowered suspension setup, just think about it and holla if you need any more help, anything I can do just ask,
-lobo-
madmax66
Jul 30, 2008 05:20 AM
PureZ
Apr 3, 2007 03:57 PM
Macgyver
Wheels, Tires & Brakes Forum
Apr 20, 2006 10:20 PM
silversprucesc3
Mar 11, 2004 08:30 AM
cialz
Jul 13, 2001 11:02 PM
