Highlander Alternator
Old Jan 27, 2005 | 06:38 PM
adiadasman's Avatar
adiadasman
Default Highlander Alternator
I remebered reading that a Toyota highlander alternator was a direct replacement for the Es300. I have a 96 btw. I searched on it and it was mentioned a few times, but can anyone confirm this 100%? Highlander alternators are not cheap, so I don't want to buy one if it doesn't fit. Also, does anyone know where to buy one from? I have searched online and everyone says they are out of stock. Also, do all the highlanders use the same alternator. I noticed that there is a 4 and 6 cylinder and also 2wd and 4wd. Thanks in advance.
Old Jan 29, 2005 | 11:20 AM
3rdelement's Avatar
3rdelement
Default alternator
Ok this is the info i found out when doing my alternator switchout 2 weeks back. The highlander looks like it should fit. but you have to order it from your local pepboys or auto parts supplier. The highlander is usually to new for them to carry the parts. What i would do if seriously considering it. Is find one in junk yard and compare the 2. The reason i didnt do it is because i dont want to overload the delicate electrical system of the es300. I had an alternator spike through my electrical system and im still finding bulbs that i am trying to replace. lol
best of luck! and definately let us know if it works.
`R
Old Jan 30, 2005 | 12:39 PM
csaxon's Avatar
csaxon
I found this on Toyotanation.com
If any of you V6 guys are looking for an upgrade to your stock 80-amp alternator, the Highlander has a 130-amp alternator option with the towing package. I installed one in my 1994 V6 Camry today and it was a direct bolt-in.
My dimming light issues have been solved. Best of all, it was only $60 shipped with a 6-month warranty. Just go to www.car-part.com and search for a 2003 Highlander alternator, then select the V6 130 amp option
Old Feb 2, 2005 | 11:24 AM
mcv30's Avatar
mcv30
so does this mean that it will fit any generation/year of es/camry(v6) or is it specific?
thanks in advance.
nlowin
14
Oct 11, 2025 08:11 AM
morphh
Jan 27, 2014 05:00 PM
canucklehe
Dec 11, 2012 04:34 AM
BadBtsz4u
Jul 5, 2006 02:26 PM
ChrisTapia
Jun 8, 2006 12:27 PM
