Engine Replacement or Repair?
Old Jan 7, 2005 | 07:14 PM
ES3's Avatar
ES3
Default Engine Replacement or Repair?
Need some advice. Long story short my good friend had my car while I was on vacation, he says he fears my timing belt may have gone, while he was cruising down the highway, he says the connecting rod punched a hole in the oil pan and that the car is leaking oil, but he says it still turns over? Anyway, I've been told a new engine would be 10-12 grand--out of the question, but that a used engine through Lexus may be around 3 grand. Huge let down, since I was going to hold onto this thing for a while,--may still. It's a '97ES300 with 130k miles. Is it worth getting an estimate and attempting to have repaired?
Any advice is appreciated!
Old Jan 7, 2005 | 07:48 PM
a13n0rma1's Avatar
a13n0rma1
10-12 grand's a new '97! Hot damn.
I'd say the used engine through Lexus option isn't so bad, but you might as well get an estimate.
Old Jan 7, 2005 | 08:07 PM
lexusk8's Avatar
lexusk8
Can't you get the ES inspected and see if just the oil pan needs to be replaced, and nothing else? That could save you a lot of money and worries down the road.
Old Jan 7, 2005 | 08:37 PM
ES3's Avatar
ES3
Yeah, even 3 grand is out of my budget at this point, but I need transportation. Thanks for the advice and suggestions guys.
Old Jan 7, 2005 | 08:46 PM
flipside909's Avatar
flipside909
Lexus Connoisseur
25 Year Member
try going to a Toyota/Lexus independent mechanic. 10-12k for an engine rebuild/swap is not worth it, unless you were doing a full on 2JZ-GTE swap w/tranny upgrade on a GS or IS.
You can buy rebuilt engines at a fair price and you don't have to buy a Lexus one. You can buy the same year Camry V6 since it's the same exact motor 1MZ-FE.
Old Jan 9, 2005 | 01:05 PM
ES3's Avatar
ES3
Isn't the camry engine a few less h.power>?
Also, I wonder if this may be the reason, despite regular oil changes:
http://consumeraffairs.com/news02/toyota_sludge.html
Ken167
Nov 19, 2016 07:02 AM
tractng
Jan 30, 2013 10:02 AM
moskiter
Automotive Care & Detailing
Jan 22, 2010 12:51 PM
ES3
Performance
Jan 9, 2005 03:49 AM
IrockLex
28
Feb 3, 2002 04:09 PM
